California Smelly...yak 2
    Uh Oh Stew,.....trying to confuse a Californian with a bunch of facts are you.........It's all about "looks" in California.......
    Quality time with the Dremel tool drum sander.......I'm thinking I might have to make a cosmetic cover over the left exhaust stub ( for "looks" ) so the shark mouth graphic wont get cut out.
ID:	33147Click image for larger version
ID:	33148Click image for larger version
ID:	33145Click image for larger version
      It is a very Stuka looking tow plane.... Headers and cans? or the stock exhaust?
      • MarnochS
        MarnochS commented
        Headers and MTW 120K Canisters as that was the main purpose of the "field upgrade".....to get more header length ....and cool winglets.
        Pictures in post #1
      I think the words "looks better" and "Smellyak" don't really go together in the same sentence... but really it isn't about looks, it is about what the aerodynamics dictate for the amount of vertical fin area in the tail is necessary to compensate for the amount of vertical surface area added in the front by the longer nose. So the full scale design did it by lengthening the fuse and adding the dorsal fin. The nose had to be lengthened for balance since the turbo prop engine is so much lighter than the big fat radial. It will be interesting to see if the model ever knows the difference between the two designs. Really cool mods, Scott!! Really enjoy watching the process. Thanks for posting.
      Remind everyone this comes from a guy who flies a Bidule 180...........
      Just sayin,...
        Just sayin,...
        Some people just go from bad to worse, but who's who among tug drivers is a very secret ballot, but all tug drivers are in front of glider guiders....most of the time...then they dump or get dumped!!!
        I'd downsize to the wimpy 150, but I'm afraid of the workload for the DG1000. There is no replacement for displacement. Anybody seen my gas can?......
          '...it's all about "looks" in California....'
          That sounds like slot-time verbiage to me!
            Exhaust stub cutaways
            Click image for larger version  Name:	IMG_4819.JPG Views:	1 Size:	70.7 KB ID:	33424Click image for larger version  Name:	IMG_4818.JPG Views:	1 Size:	70.8 KB ID:	33423
            now I have to build a rack to hang the fuselage vertically to make mounting the cowl and engine easier.
            For the Stuka "effect" ....after tow dive.......
              The Stuka effect is what I'm calling, "Thinking outside the box" Look out gliders!
                That will be so funny!
              Cowl and engine mounting .....glad that's over.....step workout......
ID:	33435Click image for larger version
              on to the canister installation.....
              • BryanB
                BryanB commented
                Loving it! Can't wait to see it with the winglets.
              Movie build Sunday...........some progress
ID:	33494Click image for larger version
ID:	33493Click image for larger version
ID:	33497Click image for larger version
                Canisters and Exhaust
ID:	33742Click image for larger version
                Tack brazing to hold things in place
ID:	33737Click image for larger version
                Found some aluminium louver vents for hot rods for hot air exhaust.
ID:	33739Click image for larger version
                  Very nice Scott! Love your idea of the louvres.
                    +1 on the louvres!
                  • kjkavaney
                    kjkavaney commented
                    "Smokin" as they say...WOW
                • #57
                  Thanks Guys,
                  The all important engine controls..... with an off-set on the choke arm for the proper geometry
                  Click image for larger version  Name:	IMG_4847.JPG Views:	1 Size:	95.1 KB ID:	33968Click image for larger version  Name:	IMG_4855.JPG Views:	1 Size:	54.3 KB ID:	33967
                  I love my Dremel 90 degree attachment to get into those spaces that need servo wire holes.
                  Click image for larger version  Name:	IMG_4853.JPG Views:	1 Size:	51.9 KB ID:	33969
                  Figured I would have my best luck with the front wind screen if I glued the pieces on first and then cut things out. Accidentally glued a good patch of skin on my finger to the wood......... couldn't get a picture of it as the camera was too far away, needless to say some quality time slowly peeling my "signaling" finger off.......
                  Click image for larger version  Name:	IMG_4856.JPG Views:	1 Size:	60.2 KB ID:	33970
                  • #58
                    Whew, glad that part's over with.
                    Click image for larger version  Name:	IMG_4857.JPG Views:	1 Size:	83.7 KB ID:	33988Click image for larger version  Name:	IMG_4858.JPG Views:	1 Size:	99.3 KB ID:	33989
                    Click image for larger version  Name:	IMG_4859.JPG Views:	1 Size:	63.8 KB ID:	33987Click image for larger version  Name:	IMG_4860.JPG Views:	1 Size:	117.3 KB ID:	33990
                    • #59
                      On to the Wing and gear mounts
                      Ordered the scale landing gear from Air World RC and they survived shipping......
ID:	34165Click image for larger version
ID:	34167Click image for larger version
                      The Air World Z-37 gear is 24mm OD so some minor adjustments was made to the mounting plates along with the new 24mm ID carbon tube as a socket.
                      • BryanB
                        BryanB commented
                        Gunny is going to have to step it up to have the coolest tow plane on the circuit!
                        Nah! What Scot is doing is totally Cool!
                    • #60
                      Looks like it costs a lot to glue the wings together
                      • MarnochS
                        MarnochS commented
                        It's just a nickel and dime project
