California Smelly...yak 2
  • Quick and dirty version of an instrument panel ..... hot off the Laser printer
    Oops- forgot to add the Transponder with ADS-b..........
    Click image for larger version  Name:	IMG_5596.JPG Views:	0 Size:	109.4 KB ID:	40081 The original full size and "canvas"
    Click image for larger version  Name:	1200260-1.jpg Views:	0 Size:	253.4 KB ID:	40080 Click image for larger version  Name:	IMG_5598.JPG Views:	0 Size:	73.0 KB ID:	40082
      'Oops- forgot to add the Transponder with ADS-b..........' lol
      Looks GREAT!
  • night time flap travel balancing - ended up with 55 degrees
    Spaghetti almost under control
    • Sand to Shape
      Custom nose means custom front windscreen pieces. Started out by making paper templates to the openings, then transferred them to vinyl paint mask applied to the new PTGE material.
      Then as is said many times......Simply....... "Sand to Shape".......easy-piezy.
      Click image for larger version  Name:	IMG_5612.JPG Views:	0 Size:	47.0 KB ID:	40113 Click image for larger version  Name:	IMG_5613.JPG Views:	0 Size:	49.4 KB ID:	40114 Click image for larger version  Name:	IMG_5614.JPG Views:	0 Size:	122.5 KB ID:	40115
      Click image for larger version  Name:	IMG_5617.JPG Views:	0 Size:	46.4 KB ID:	40116
      • BryanB
        BryanB commented
        You gotta love flat panels! I hate having to make plugs for compound curved windshields.
    • Factory Fresh windows ........anti-hanger-rash guards are staying on for the time being.
      Click image for larger version  Name:	IMG_5621.JPG Views:	0 Size:	94.5 KB ID:	40123
      • Man that's looking great! Do have an all up weight yet?
        • a very svelte 23 kg
          Flying Tiger...ized
          Click image for larger version  Name:	IMG_5636-1.jpg Views:	0 Size:	134.5 KB ID:	40135 Working on the door hinges..... and balance ( looks like about 0.45 kg on the firewall is necessary )
            Absolutely love it Scot!
        • For the metric system challenged:
          23 kg = 50.7 lbs.
          0.45 kg = 0.99 lbs.
          • MarnochS
            MarnochS commented
            Four pounds lighter than my Bidule 170 and with more wing area....
            That's only 3.62 stone!
        • Hope you and the SMELLY-YAK-2 can make it down to Fallbrook to our First Saturday of the Month Aerotow some time. It looks like it could tow a full size.
          Jim
          • Stunning Scott....kevin
            • Yes stunning! but...
              The spinner needs to be painted black. Then it's complete and will pop with the rest of the model.
              • BryanB
                BryanB commented
                Yep, black with a red or yellow spiral painted on it!
            • Thanks Guys
              I'm partial to Blue.
Name:	Spinner color.jpg
ID:	40210 Click image for larger version
Name:	Spinner color 2.jpg
              And black for comparison
Name:	Spinner color 1.jpg
              • BryanB
                BryanB commented
                OK, blue with a white spiral then!
              • MarnochS
                MarnochS commented
                Now.....there's an Idea......
            • Something like this maybe?
              Click image for larger version  Name:	image_16023BlueWht.jpg Views:	0 Size:	30.5 KB ID:	40222
              Or this?
              • MarnochS
                MarnochS commented
                Excellent....
            • All kinds of options too........looks like I better order a second spinner
              Click image for larger version  Name:	Aircraft Jet Engine Spinner - Aircraft Nerds.png Views:	0 Size:	299.6 KB ID:	40228
              What spinner should the Smelly wear today.........and , of course, ......"does this spinner make me look fat"......
              • yellow spiral and if done in 3 blade im sure it will look thinner than 2 blade... this plane begs for the new release soon of the xicoy x45tp motor up front not much change in cost from da150 with pipes and headers.............
                • MarnochS
                  MarnochS commented
                  True,....it would be uber-cool with a Turbo Prop.
                  Unfortunately, not very practical for towing, also the X45TP is only equivlant to a DA85 in power.
                  A JetCat SPT10 or 15 would be more practical ............but then fuel burn rate becomes an issue. the SPT10 burns 11.8 oz at full power and the 15 is considerably higher.
                  I would have to install functional "drop" tanks to carry all that extra fuel.
                  ............And of course 3 or 4 large fire extinguishers.
              • have peter scale it down to 2/3 original and x45 it.... im in for a kit if he does............dying to put that motor to work when it gets released soon.
                but for now your plane looks great as is.
