California Bidules
  • California Bidules
    Bidule 170's have come to California The unveiling occurred at the Visalia Fall AeroTow, Mac was gracious enough to open the box so we could all "look inside". Click image for larger version
Name:	Happy Campers.JPG
ID:	4938 Mac has S/N - 66 and I have S/N - 71 Scott
    ahh...., it's a California "Thing". You will enjoy it.
      Thanks Asher, we're both looking forward to them
      Firewall reinforcement
      I opted for West System 404 (high strength adhesive) to form a filet around the backside of the firewall (there were some large gaps) and then put down 6 oz fiberglass cloth ( 3' up the sides )
      Sealed off the existing T-nuts with Vaseline coated screws, then ran a Tap threw the threads after cleaning out the fiberglass.off the back side
      Scott
ID:	4996 Click image for larger version
ID:	4998 Click image for larger version
ID:	4999 Click image for larger version
ID:	5001 Click image for larger version
      Ran a bead of epoxy / colloidal silica (406) filler along all the forward glue joints as there were some holes...
      Used a 10cc syringe (application) and a Popsicle stick (smoothing).
        Hi Scott,
        Are you planning on a servo saver setup for the nose gear?
          Hi Len,
          Using the old tag line "bigger is better"....a HS-5765 MH HV is tasked for steering duties.
            Exhaust System
            Playing with the K&S 3095-6 Canisters and headers before breaking out the torch.
ID:	5076 Click image for larger version
              LitePilot Bob .....starting to chomp at the bit.....kinda looks like Elvis.....well 42% sized....
                Fun with Wheels
                Decided to upgrade the wheels with ball bearings(flanged), after taking a few measurements, turns out I needed F608ZZ for the main wheels and F626ZZ for the nose wheel.
                Also for the upgrade I need metric step drills, one with a 22mm step and one with a 19mm step (which is a little more difficult to find).
                Instead of using a PVC pipe spacer, I cut plywood plugs and glued them together to get the proper spacing, and 0.080 G10 for the bearing spacer
                Found I made the spacer a little too wide as the tire was rotating on the rim, so off to the band saw to cut the spacer in half......now the rim is griping the tire properly.
ID:	5507 Click image for larger version
ID:	5509 Click image for larger version
                Main wheels in progress - checking the width......
ID:	5512 Click image for larger version
                  Love the pilot Scott.
                  The downside to the bearings on the wheels is stopping this big plane from rolling. Some consideration needs to be how to put breaks on these things without strapping servos to the landing gear legs.
                    I have a baby one coming, the 111.
                    Brian
                      Congrats Brian.
                      We had the opportunity to fly the 111 in Cumberland last month. Stephane has installed a DA 100 on his and the performance was stunning. It flies just like the big one and pulls like a Stallion
                      LEN
                        Super Cool Brian....welcome to Bidule-palooza.......of course, since this is California..."All Bidule's are Created Equal".....
                        Some sundry items...
                        Added a G10 off-set arm to the choke so the servo will actually be able to open it.
                        Added a tube to the rear air frame to keep the servo wires under control
                        got my REVOC wing and tail bags - very nice and ORANGE to boot
                          Hard points for the canister muffler mounts
                          Since the bottom skin of the Bidule is just balsa and will crush when I install the Comfort mount standoffs I figured I'd just install some 0.080 G10 fiberglass hard points.
ID:	5807 Click image for larger version
                          The inside of the fuselage has been reinforced with 1/8" aircraft ply across the bottom
                          Scott
                            Scott,
                            Have you noticed the rake of the main gear...and have you thought about which why to mount it (forward or rearward rake)?
                            Jim
                            FWIW, Len has his mounted with rearward rake.
                            • MarnochS
                              MarnochS commented
                              Hi Jim,
                              I don't think it matters too much as it would only be about 1/2" difference in the main wheel position. Kinda boils down to Pilot Preference.... Classic Cessna look or RV8 look. I went with the Classic Cessna look.
                            Where do you guys get G10?
                            • MarnochS
                              MarnochS commented
                              Hi Steve,
                              Ebay is probably the easiest way to go, just do a search for G10 Phenolic or fiberglass Sheet
                              On occasion I've laminated fiberglass cloth together between freezer paper to get what I needed.
