Bidule 170
  • Bidule 170
    Here is the pictures of my friend Pascal building his Bidule 170
    Should help someone here I guess....
    Great to have this, thank you Stephane.
    Kit looks good overall. I think there will be a few areas to reinforce a bit more just because of the use the airframe will have as a tug. Should work out well though.
    I will be using a DA 150 in mine with MTW canisters and flex headers for the muffler system, attaching them to the bottom of the fuselage on the outside.
    Likely starting the build in about a week or two and I will post information and pictures as I move forward.
    Bob
      Bob
      "As soon as I get the table finished and out of the shop, should be in a week or two, almost done, just have to finish it now"
      If I had a dine for every time I heard that!!!!!
      lol
      LEN
        He was finishing that table for my junior prom.
        We want airplane build photos!
          Ok.....so I take a while to make tables, what can I say........it is like a fine wine, it takes time to age to perfection.
          Honestly, I am working on the Bidule............I already have been thinking about the excuses I will use for how long it takes to get it completed
          Need to decide on the servos and electronics that will be installed and get that in place so everything is there as I build. I should have all that done in the next couple days here.
          Hey Len, don't you have one also ? We should both be sharing our builds here..........although I bet yours is already close to being finished !
          I'll have photos this coming weekend...........like many have said "it isn't real unless there are photos !"
          Bob
            Stephane,
            Thanks for the links to Pascal's photo build. I always enjoy following his work.
            Bob, Len , Jim, below is a link to RC-network.de thread on the Bidule 116. There are some good "heads-up" points regarding vulnerable areas. I imagine some of this will apply to the 170 as well. The thread is an early version of the 116 model. I believe most of the issues mentioned in the thread have been addressed but it would be prudent to look at some strengthening as Bob has mentioned. Google translate does enough to get the basics of the thread.
            I'll be going with HiTec servos(5645 on surfaces and 7955 on nose gear and release), basic Jeti radio install and I'm considering a DLE 120 on cannisters.
            http://www.rc-network.de/forum/showt...ghlight=bidule
              So who picked up the Bidule's, as "The Transporter" was not available
              SCC AAA TT
                Drove up and picked mine up last week.
                To Arab, Al, that is.
                  Where did you have to drive?
                  How much are the kits?
                    Pete,
                    Bob M arranged a shipment of 2- 170's and 2-111's from TopModell France via Icare. I drove to my work to pick mine up.... It came FedEx from Icare.
                    The 170 is 1299 Euro and the 111 is 749. This did not include shipping to Icare or to my work.
                    I've been wanting to try a trike tug for awhile and the Bidule seems to be well regarded.
                      When Icare-rc informed us the planes had arrived in Canada, one of our club members, Scot Stewart offered to drive up to Canada and get them for us ( three of us were in CT for the Aerotow ).
                      It was a 10 hr round trip for Scot, so to make it worth his time, he opted to pick up an H-Models 6.6m Arcus while he was there for himself.
                      Getting the planes hand delivered without the chance of shipping damage is a good deal in my book
                      It pays to have great friends.
                      Thanks Scot.
                        Many thanks to Scot also for making the trek north and picking up the planes !
                        Just wanted to ask what people are thinking of in terms of servos for the plane.
                        My thoughts are to use high torque metal geared HV serovos such as the JR 8911HV or the Spectrum A6260HV. These would be for the major flying surfaces: ailerons (2), flaps (2), elevators (2), rudders (2), tow release (1), and the nose gear (1). Lower torque metal geared servos would be used for the throttle, and the choke.
                        My plan is to use a PowerSafe 12 channel receiver and dual 5200mAh Li Ion batteries for the radio equipment and servos.
                        An additional pack for the electronic ignition on the engine, somewhere between 2600mAh to 5200mAh. This should be more than enough to run the engine for quite a while without problems I would think.
                        In addition to this an electronic ignition cut-off of some sort, onto style, that can be used for the engine. I think there are several out there that aren't too expensive and are very reliable.
                        Looking forward to hearing everyone else's thoughts on this.
                        Bob
                          Ignition Kill
                          I've been using the Spectrum 6260HV servos and I have to say they're pretty powerful.
                          As a separate note : I still like the Hitec 7955 servo for any retract installation, since standard "retract" servos all see to be gutless.
                            Remember Bidule owners, we can help you out with Servo's Receiver and Engines or anything else you may need!
                            Thank's Asher for your order.
                            The Model Box 205 978 8787
                            SCC AAA TT
                              I started preliminary work on the Bidule 170 this week. I have been test fitting some of the various pieces and looking at where to reinforce with ply, balsa and hardwood tri stock, and also some carbon fiber cloth or fiberglass with slow setting resin.
                              Looks pretty good overall.
                              It is a big plane though. I have mounted the DA 170 temporarily and have the prop and 5" spinner in place to start making some measurements for the spacing from the firewall to the back of the engine mount.
                              ​The DA 170 needs to have standoffs that place the back of the engine mount plate 1.625" from the firewall. I don't want to use individual standoffs due to the size and power of the engine as well as the distance from the firewall.
                              There are a couple solutions I have thought of so far, and I'm certain there are many others that you guys know that would probably work better than my ideas.
                              I found a company that makes custom made mounting standoffs: Blazing Star Products.
                              They produce CNC rectangular mount blocks for the specific engine and dimensions out of aluminum block. The resulting standoff is actually a rectangular piece that is then routed out inside, but has all 4 of the mounting positions for the thru bolts connected by material that is not routed or machined away. They look very strong as well as relatively lightweight.
                              I'm not sure if they are actively producing them right now. I put in a message on their FaceBook page and haven'y had a response as of yet.
                              The other option would be a built-up wood spacer or standoff. This could be a series of rectangular ply plates that have the center cut out so it looks like a box without a top or bottom. I would leave enough material around where the bolts go through to make sure it is strong enough to retain the engine and not let to rotate due to torque. This would be put together using aircraft grade ply and slow setting resin to make certain it is strong enough. It can also be wrapped on the outside by a layer or two of fiberglass or carbon fiber cloth and slow setting resin to make it more reinforced.
                              I think there are a couple companies out there that make items similar to these. I know I saw some CNC ply plates of 1/2" and 1/4 aircraft ply that are then glued together to make the proper spacing of the final standoff.
                              I decided to go with the Spectrum servos. A6260 HV for the ailerons, flaps, and elevators. A6150 HV for the rudders, nose wheel steering, tow release, engine throttle and engine choke. A Spectrum PowerSafe 12 channel receiver and a pair of Li Ion 5200Ah batteries for the radio system. A 5200Ah battery for the ignition with an electronic optical ignition kill switch from Evolution engines.
                              Mejzlik 28.5 x 12 prop, Tru Turn 5" P-51 3 blade spinner with lite backplate.
                              I'll use MTW110H canisters for the exhaust system, but I have to work on the headers as I need a drop of about 120mm for them to fit the placement of the engine on the fuselage. I'll use a pair of mounting rings on the bottom of the fuselage to hold each of the canisters so they don't flex or move and cause the headers to eventually fail. The bottom of the fuselage bottom will be reinforced on the inside with additional ply plates and trip stock where the attachment rings are placed.
                              I know that MTW makes flex headers to 90mm. Not certain if I might be able to use silver solder and a torch with the individual component kits that MTW has and make my own custom flex headers to the right drop dimension. Jim, Len, and Steve....you may have some good ideas about this and if a 120mm drop might be too much and result in too much stress on the header system.
                              Here is a picture of the fuselage with the landing gear and engine temporarily in place for measurements.
                              Bob
