  • sorry for not posting in a while... Been building the other wing.
    starting to look like an airplane!
    • Gene C
      Gene C commented
      Looking good! Love the tundra tires, very practical for a tug.
    • MarnochS
      MarnochS commented
      Excellent !
  • Beach aerotowing lol....
    • FAA Registry - N757
      Serial Number 18504306 Status Valid
      Manufacturer Name CESSNA Certificate Issue Date 12/11/1981
      Model A185F Expiration Date 02/28/2022
      Type Aircraft Fixed Wing Single-Engine Type Engine Reciprocating
      Pending Number Change None Dealer No
      Date Change Authorized None Mode S Code (base 8 / oct) 52432011
      MFR Year 1981 Mode S Code (base 16 / hex) AA3409
      Type Registration Government Fractional Owner NO
      Registered Owner
      Name UNITED STATES DEPARTMENT OF INTERIOR
      Street OFFICE OF AVIATION SERVICES
      300 E MALLARD DR STE 200
      City BOISE State IDAHO
      County ADA Zip Code 83706-3991
      Country UNITED STATES
      Airworthiness
      Engine Manufacturer CONT MOTOR Classification Standard
      Engine Model IO 520 SERIES Category Normal
      A/W Date 07/20/1981 Exception Code No
      • Sorry guys - my OCD kicks in every time I see an N-number I have to look it up.
          Neat info...
      • Hello everyone, Back to the regular schedule... Watching resin dry on the cowl plug can get boring, so I'll post instead.
        Sanding the LE and TE caps on the ail. & flaps. Easy peazy! What else is easy is the included flap drill jig. It's a hit on my PT-19.
        Check it out how it's done.
        • There is a center line drawn down the middle of the jig. Line it up on your hinge lines and hold it to the wing side or flap side.
          • To shape the LE, glue on the wing tip and tape on the wing root cap. Carve and sand to shape.
            • Hinging the ailerons. There are marking templates included for the bevels.
              • And installing the horn.
                • Back to the ailerons for a moment. I created this hinge center line tool because the Robart Drill Guide doesn't line up from the wing to the aileron do to the wide tabs. This misalignment is about a 1/16". The top skin of the wing climbs steeply while the ail. drops. also a picture of the bevel template.
                  • Well designed parts, attention to detail, and that special Gunny quality. What else is there to say than WOWZA!!! 😃
                      Thank you Jim.
                      Triple that, WOWZA WOWZA WOWZA
                  • Well, the wings are done and now lets mount them onto the fuselage. The root end cap for now is just slipped into place.
                    • Now that the wings are mounted... My favorite part of the build which is fun is mounting the struts.
                      The original plan was to square cut them but I did not like the way they looked. The full scale was cut on an angle. So, I spent a couple of days to make cutting jigs for the aluminum struts.
                      Well, like Jim said "Attention to detail" does make it look a lot nicer. The struts are cut to length and on there respective angles in the kit.
                      The long bolts need to be double "lock tited" nutted together. These are in the fuselage end of the mounting. The reason for the long head is so you can grab them and remove them out of their recessed spot. the shorter ones are up at the wings. Water jet cut and pre bent steel fittings along with a bag of little airfoil spacers. These spacers get glued on the fittings and sanded to fit inside the strut tubes.
ID:	36155Click image for larger version
                      • Roughen up, epoxy and shim it away from the fuselage with 1/16" ply spacer and check alignment.
                        • Here are the jigs used to cut the struts at their respective angles.
                            Have to clarify about these jigs. These are for the shop to cut and produce all the angles and ends of the struts.
