  • #91
    So now the elev and stab get cut and separated. The build tabs removed, Servo installed and supplied is templates to locate the exits in the bottom sheeting. Trace the templates and mark Lft or Rt.
    • #92
      Sheeting the bottom of the stab and elev. Using the templates to locate the servo arm exits.
      • #93
        Adding the leading and trailing edges along with the ply root end cap.
        • #94
          The balance on the elevators... On the plans show the scale balance, sport scale balance and no balance for tow plane duty. You can kinda see them (the diagonals) on the lite ply center piece.
          • #95
            A little sanding and hinging.
            • #96
              Pushrod and horn. And the finished tail assembly.
                Very nice work, Gunny!
            • #97
              Beautiful Gunny!
              Love it!
              • #98
                Incredible skills. Always looking forward to the next segment.
                Regards Dean
                • #99
                  Top Quality as always Gunny
                  • Thank you Guys! Makes me want to post more.
                    • Well Dean, here is the next segment. Wing Structure begins.
                      Pretty much self explanatory.
                      • So the outer wing panel is a continuous build off the inboard wing panel. The outboard bottom spar sits on a "jack stand" and the ribs have build tabs that progressively get longer as they approach out towards the tip. The wing break joint assembly has a CNC 1/4" birch ply joiner that gets epoxied to the bottom spars. The joiner and ribs are half notched so they key into one another.
                        • Add another rib and then the servo wire conduit tubes are slipped into place. Then the remaining ribs are all glued in place.
                          • Now the drag spar gets glued into position.
                            • And the drag spars on the outboard panel.
