  • #61
    Ok, back at it with the engine box.
    • #62
      Top decking and instrument panel which is a two piece decal.
      • #63
        Wind shield installation. The windshield is laser cut from .030" PETG with all the screw holes. Also included is all the laser cut .010" thick G-10 windshield frames and screws.
        Click image for larger version  Name:	DSC_0937.JPG Views:	1 Size:	95.8 KB ID:	33943Click image for larger version  Name:	DSC_0960.JPG Views:	1 Size:	93.1 KB ID:	33942
        Click image for larger version  Name:	DSC_0964.JPG Views:	1 Size:	89.5 KB ID:	33944
        Click image for larger version  Name:	DSC_0996.JPG Views:	1 Size:	116.9 KB ID:	33945
        Click image for larger version  Name:	DSC_0998.JPG Views:	1 Size:	132.6 KB ID:	33946
        • #64
          What 'vitamins' does this bird need to fly? DA 170... 150?
            100 to 120 mg I mean cc for sport scale non aerotowing.... And 150 to 180cc for aerotowing. So far everything is designed around the DA 150.
        • #65
          The Luggage Door. There is only one on the left side and it's behind the T.E. of the wing. This to me will be a great place to mount the Rx switches.The kit will include the offset hinges and magnets.
          • #66
            The main doors. They are big and have three magnets and an actual latch. The hinges are from G-10.
            • #67
              And the door latch witch also is included.
              • #68
                Credits: Jim D. for the luggage door hinges and the top front corner of the main door additional magnets.
                Kevin K. for the idea of adding a positive latch to the main door.
                Jeff D. for the source of the latch mechanism (which actually was for my generator cover project)
                • #69
                  Wow! Awesome project Gunny! Is the windshield flat wrap or is is formed?
                    Laser cut flat wrapped
                • #70
                  Here is a picture of the windshield with these G-10 frames glued to the glass. These frames reinforce the glass and prevent the whoopdies between the screws.
                  • #71
                    The fuel tank platform.
                    • #72
                      Window frame extensions. 1/16" thk. ply glue into the fuselage to bring the side and top windows flush. You can go through a bucket of binder clips easily....
                      So i just used the glass to "clamp" those frames into place while the glue dries. Not to worry about accidentally gluing them in yet because the protective wrapping is still on. They will be glued in after the model is covered.
                      • #73
                        Tail wheel and main wheels. The tail wheel and assembly is included in the kit. The 10" main wheels and G-10 hub caps shown will be an option for the kit.
                        • #74
                          Tail wheels really take a beating. FWIW- consider making the portion mounted in the fuselage have its axis run through the tire contact patch. That reduces 'lever' forces in side load conditions.
                            I think I know what you are trying to say... It's 7/32" dia. 1095 music wire and set up as a torsion rod. I tested it on my hydraulic test bed weighing 50 lbs. There's a video of it on my web site. But not to worry, because I'll give it to Kevin K. and let him put it to the ultimate tests with his STOL Tundra type tail wheel landings,
