ID:	33490 The tail wheel assembly mount.
      Gunny,
      What are you planning on for covering and finishing? Always enjoy seeing your designs come together, they are outstanding!!
        Thanks, Ultracoat for the entire airframe and Krylon paint for the cowl and landing gear.
      Click image for larger version  Name:	 Views:	1 Size:	104.5 KB ID:	33514Click image for larger version  Name:	 Views:	1 Size:	104.4 KB ID:	33513
      The fuselage bottom and top sub assemblies. To get the rounded corners of the fuselage is achieved by these assemblies first having 1/4" square balsa sticks glued to the bottom edge and then along side of these is 3/8" balsa triangle stock,
        Click image for larger version  Name:	 Views:	1 Size:	96.7 KB ID:	33516Click image for larger version  Name:	 Views:	1 Size:	139.3 KB ID:	33517Click image for larger version  Name:	 Views:	1 Size:	97.0 KB ID:	33518Click image for larger version  Name:	 Views:	1 Size:	118.2 KB ID:	33519 The fuselage sides and doublers are assembled. The alignment of gluing on the doubler is via the six 1/8" dia. dowel alignment pegs.
          So i just wanted to say that this is a general build thread. (Kinda like a synopsis) The kit like all of my other kits has a step by step construction manual with TONS of color photos which is laser printed and wire bound. In the past I used to finish the prototype and sit down and do the manual. Ugh! I would sit there for a month straight trying to figure out what I was trying to show. So now i take about 100 pictures and then do those steps while it's still fresh in my mind.
            Watching all the way Gunny, nice stuff
              Much appreciated, Thanks Jeremy!
            Click image for larger version  Name:	 Views:	1 Size:	124.7 KB ID:	33542Click image for larger version  Name:	 Views:	1 Size:	85.9 KB ID:	33543Click image for larger version  Name:	 Views:	1 Size:	114.6 KB ID:	33544
            The fuselage starts its aft construction assembly flat on the work bench.
ID:	33546Click image for larger version
ID:	33547Click image for larger version
                The fuselage sides are hung on (glued) along with the rear top section. Then the remaining CNC cut birch ply formers are epoxied into place.
              Click image for larger version  Name:	DSC_0355.JPG Views:	1 Size:	71.6 KB ID:	33552Click image for larger version  Name:	DSC_0371.JPG Views:	1 Size:	102.2 KB ID:	33553
              Click image for larger version  Name:	DSC_0373.JPG Views:	1 Size:	106.0 KB ID:	33551
              The landing gear mounting plate is not only just tied into the fuselage side but onto the main 3/8" birch ply former.
                The cockpit cabin floor will give you plenty of room for securing batteries, receivers, telemetry etc. etc.
ID:	33583Click image for larger version
ID:	33585Click image for larger version
                  and some under floor reinforcing is added.
ID:	33588Click image for larger version
ID:	33589Click image for larger version
                    Forward fuse. bottom pieces added into place.
ID:	33595Click image for larger version
                      Top fuse/wing structure.
ID:	33598Click image for larger version
ID:	33599Click image for larger version
ID:	33600Click image for larger version
                        Super nice. You're making it look too easy!
                          Thank you yyz, I try to make it easy with interlocking parts and tabs. What makes it even easier will be the instruction manual.
                        I just had to post this picture. WOW!
                        Click image for larger version  Name:	image.jpeg Views:	1 Size:	43.0 KB ID:	33615
