California Smelly...yak 2
    Pretty cool! Blue foam is great!
      Cowl separation so I can glass it for plug purposes. The 3M 77 spray adhesive did a good job of keeping things together.
ID:	32628Click image for larger version
      Since I'm going to need tail weight I might as well put the flight / ignition batteries in the back. Used a CamLoc fastener the make access easy.
      I liked Len's cover plate for access to the tail wheel servo
ID:	32631Click image for larger version
        Nice stuff Scott, but as you made it a turbine version, you should install a turbine!!
        Who's CamLok are you using?
          Hi Jeremy,
          The CamLoc thats pictured are CamLoc 4002-3 ( Cad plated , 0.111-0.141 depth ) series Studs and the Cad plated receptacles. I see on the Aircraft-Spruce website there are a couple of options now. It was a toss-up weather to go Phillips or slotted......all depends what type of hole / dent you want to put in the skin when you miss......
          The turbine would be super cool but just not practical for towing and the 25 hr maintenance interval is a bit of a hindrance.
          Scott
            Scott, super cool! I hope this new tug gets a chance to tow my repaired KA-6 this summer. Maybe I should say, I hope my KA-6 can be towed up by your new tug this coming summer. Thanks again.
            Larry
              Hi Larry,
              Looking forward to towing your big KA-6.
              Some fun stuff today, made the little turtle deck on top of the cockpit and covered it with 1/64 ply. I used overhead projector clear sheets to copy the profile image off my computer screen after zooming in to get the approximate size.
              Click image for larger version  Name:	IMG_4730.JPG Views:	1 Size:	83.3 KB ID:	32706
              Since the instrument panel and sheeting is a different shape than the Radial cowl, I used some paper and tape to approximate the correct shape and then "sanded to shape".
              Click image for larger version  Name:	IMG_4734.JPG Views:	1 Size:	93.5 KB ID:	32702Click image for larger version  Name:	IMG_4733.JPG Views:	1 Size:	56.4 KB ID:	32705Click image for larger version  Name:	IMG_4735.JPG Views:	1 Size:	55.2 KB ID:	32704
              Next step is some fiberglass on the forward deck and then the Cowl
              Click image for larger version  Name:	IMG_4737.JPG Views:	1 Size:	96.1 KB ID:	32707Click image for larger version  Name:	IMG_4738.JPG Views:	1 Size:	101.9 KB ID:	32703Click image for larger version  Name:	IMG_4739.JPG Views:	1 Size:	109.0 KB ID:	32708
                Getting closer to being a Plug.....primer....sand....primer....sand.....prim er......sand...
                the white primer doesn't build up very much like the gray stuff (primer&filler) from Krylon.
                Click image for larger version  Name:	IMG_4741.JPG Views:	1 Size:	100.3 KB ID:	32771Click image for larger version  Name:	IMG_4742.JPG Views:	1 Size:	95.4 KB ID:	32770.
                  Fun with Epoxy & fiberglass....
                  mocked up a parting board with some construction paper and then transferred to some 1/8" plywood. Covered it with some leftover UltraCote. Who says a parting board has to be white......
                  Attached with hot melt glue after waxing the ..... out of the plug.
ID:	32857Click image for larger version
ID:	32855Click image for larger version
                  I'm committed now..........for better or worse....I'm planning on a 3 part mold......easy part first......
ID:	32856Click image for larger version
                  Graphite powder gel coat and then glass and then mat ( the stuff that is needle like when you get some epoxy on a fiber )
                    So....the hot melt glue did a little damage to the plug, not much , just melted the primer......on a good note, the Frekote 700-NC is super cool as the parting board came off with out a problem.
                    Click image for larger version  Name:	IMG_4749.JPG Views:	1 Size:	52.7 KB ID:	32907
                    Next step is the front parting board.....a little more challenging to construct but the construction paper made is pretty simple.
                    Click image for larger version  Name:	IMG_4752.JPG Views:	1 Size:	92.1 KB ID:	32905
                    Stickers via USPS.......and more fiberglass via UPS and http://www.Thayercraft.com
                    Click image for larger version  Name:	IMG_4750.JPG Views:	1 Size:	102.6 KB ID:	32906 Click image for larger version  Name:	IMG_4753.JPG Views:	1 Size:	90.0 KB ID:	32908
                      Productive day on the Cowl mold
                      Saw a video on YouTube where they used the partall wax to seal the seams and thought I'd give that a try......It would work really good if I'd have painted my plug with a two part epoxy primer. Since it was only rattle can primer, the wax partially removed some of the primer ( food for thought next time....). Other than that, it worked great......
ID:	32930Click image for larger version
ID:	32931Click image for larger version
ID:	32935Click image for larger version
                      Then on to the other side......
ID:	32932Click image for larger version
                      Now, the real trick will be to extract the plug........
                      • French1
                        French1 commented
                        Well Done Scott, really great work!
                      Successful Extraction ...YEA !!!
ID:	32956Click image for larger version
ID:	32957Click image for larger version
ID:	32955Click image for larger version
                      After some cleanup with solvent to get the primer out ....time for the Frekote Mold Sealer ( FMS ) wipe on process.
                        Nice work with the plug and molds. Builds arm muscle, too!
                          Thanks Mike.
                          Two layers of 5.8 oz plain weave. On the intake scoop to spinner transition, it's a bit of a severe angle.....found if I cut a 1" strip at a 45 degree angel to the weave, it lays down nicely.
ID:	33005Click image for larger version
                          Reinforcing tapes and some 410 microlight fairing filler on the intake scoop.
ID:	33004Click image for larger version
                            Wouldn't it be nice to have some of those fancy bladders to put in there to hold the glass in place in an assembled mold? Nice work with a tedious process!
                          Going with a split cowl and Ring mount so I added the divider (two layers of 1" standard fiberglass tape ( Partall Film #10 brushed on the top cowl )
ID:	33026Click image for larger version
                          and then I couldn't stand it any longer and just had to get it out of the mold.......
ID:	33025Click image for larger version
                          YEA !! !!
                            Very interesting!
