Top Model Bidule 170 Fixer Upper Deal
  • Top Model Bidule 170 Fixer Upper Deal
    I have my Bidule 170 for sale. It has been a very solid performer for the past 3 or so years, but recently at Cumberland had a main landing gear failure.
    Click image for larger version  Name:	_DSC4444.jpg Views:	1 Size:	168.9 KB ID:	28866
    The Bidule was not crashhed when the main landing gear failed. The failure is due to the stress of the continuous take-offs and landings as a tow plane over the past few years. Repair for the the airframe is limited to the bottom center of the fuselage where the main landing gear is mounted.
    The failure itself was on landing, with the plane just touching down and the main ear and gear block folded backwards, letting the plane come to rest. The engine and prop were above the ground during this and did not have any issues of the prop catching the ground. The engine was stopped with the kill switch and then the plane was brought back and packed for the return trip home.
    Note that the main gear and main wheels were not damaged, nor has the nose wheel or steering system been damaged. All are in good mechanical order, only requiring the bottom of the fuselage to be repaird so the main gear and wheels can be attached again.
    The failure was actually pretty uneventful, other than the realization the fuselage would need some repair work to make the Bidule airworthy again.
    I have decided to sell it "as is" either with or without engine as my priority in the shop right now is building my new Smellyak and getting it ready to fly.
    The Bidule 170 includes all the electronic equipment installed along with the accessory wing and tail covers and a silver stretch fabric canopy cover:
    • Aileron, Flap, Elevator, and Tow Release Servos: Spektrum A6260 Hi Torque HV
    • Rudders, Throttle, and Choke Servos: Spektrum A6150 HV
    • Nose Steering Servo: Spektrum S9020 1/5 scale servo along with the modified steering system developed by Scot Stewart and Len Buffinton
    • Receiver is a Spektrum AR 12120 PowerSafe receiver with EC3 battery plugs
    • Electronic Ignition Swith is a PowerBox SparkSwitch set at 5.9v for the DA170 Ignition System. (This has a built-in voltage regulator so a wide range of batteries can be used for the iginition system and be regulated to 5.9v to safely operate the DA ignition)
    • 100 oz main tank and a 12 oz header tank
    • DA 170 engine, which runs perfectly, never crashed or damaged and only used on the Bidule. Uses 93 octane gasoline mixture 40:1 with Redline oil.
    • Custom aluminum CNC engine mount
    • KS Comfort Mount Headers
    • MTW RE3 Tuned Pipes: Please note these have been damaged by the landing gear when it failed, see pictures below for reference
    • Air Models 29 x 12 3 blade carbon fiber prop (not damaged and in excellent shape)
    • Tru Turn aluminum spinner with lite backplate, drilled for the DA 170 engine
    • Revoc wing and tail covers
    • Silver stretch fabric canopy cover
    The fuselage is structurally sound (firewall through the tail section). The formers and fuselage sides are good, the wing mount and anti-rotation pin is also good.
    Click image for larger version  Name:	_DSC4732.jpg Views:	1 Size:	149.8 KB ID:	28883Click image for larger version  Name:	_DSC4737.jpg Views:	1 Size:	142.5 KB ID:	28886Click image for larger version  Name:	_DSC4741.jpg Views:	1 Size:	139.0 KB ID:	28885
    Click image for larger version  Name:	_DSC4757.jpg Views:	1 Size:	133.6 KB ID:	28889Click image for larger version  Name:	_DSC4752.jpg Views:	1 Size:	137.4 KB ID:	28887Click image for larger version  Name:	_DSC4748.jpg Views:	1 Size:	157.9 KB ID:	28888
    Click image for larger version  Name:	image_10932.jpg Views:	1 Size:	66.5 KB ID:	28876 Click image for larger version  Name:	image_10934.jpg Views:	1 Size:	66.8 KB ID:	28878Click image for larger version  Name:	image_10935.jpg Views:	1 Size:	89.7 KB ID:	28879
    Click image for larger version  Name:	_DSC4721.jpg Views:	1 Size:	59.5 KB ID:	28880Click image for larger version  Name:	_DSC4726.jpg Views:	1 Size:	56.3 KB ID:	28881Click image for larger version  Name:	_DSC4681.jpg Views:	1 Size:	52.7 KB ID:	28877Click image for larger version  Name:	_DSC4687.jpg Views:	1 Size:	53.7 KB ID:	28884Click image for larger version  Name:	_DSC4675.jpg Views:	1 Size:	77.5 KB ID:	28882Click image for larger version  Name:	_DSC4717.jpg Views:	1 Size:	65.8 KB ID:	28905Click image for larger version  Name:	_DSC4483.jpg Views:	1 Size:	82.1 KB ID:	28906
    Engine throttle and choke are Spektrum A6150 HV servos
    Steering system for the nose wheel:
    Click image for larger version  Name:	_DSC4477.jpg Views:	1 Size:	98.8 KB ID:	28922
    This uses the reinforced steerinf system developed by Scot Stewart and Len Buffinton with a Spektrum S9020 1/5 scale servo
    Wing panels and removable tail are also sound and in great shape, includes Revoc covers:
    Click image for larger version  Name:	_DSC4451.jpg Views:	1 Size:	191.5 KB ID:	28893Click image for larger version  Name:	_DSC4461.jpg Views:	1 Size:	159.1 KB ID:	28891Click image for larger version  Name:	_DSC4458.jpg Views:	1 Size:	134.0 KB ID:	28890
    Click image for larger version  Name:	_DSC4455.jpg Views:	1 Size:	136.1 KB ID:	28894Click image for larger version  Name:	_DSC4463.jpg Views:	1 Size:	160.6 KB ID:	28892Click image for larger version  Name:	_DSC4466.jpg Views:	1 Size:	48.9 KB ID:	28903
    Flaps and Ailerons use Spektrum A6260 Hi Torque HV servos
    The removable tail is also in excellent shape, includes Revoc covers:
    Click image for larger version  Name:	_DSC4447.jpg Views:	1 Size:	224.7 KB ID:	28901Click image for larger version  Name:	_DSC4449.jpg Views:	1 Size:	93.8 KB ID:	28899
    Click image for larger version  Name:	_DSC4495.jpg Views:	1 Size:	69.4 KB ID:	28895Click image for larger version  Name:	_DSC4497.jpg Views:	1 Size:	59.6 KB ID:	28896Click image for larger version  Name:	_DSC4500.jpg Views:	1 Size:	32.1 KB ID:	28898Click image for larger version  Name:	_DSC4505.jpg Views:	1 Size:	87.2 KB ID:	28902
    Click image for larger version  Name:	_DSC4490.jpg Views:	1 Size:	168.4 KB ID:	28900Click image for larger version  Name:	_DSC4498.jpg Views:	1 Size:	164.7 KB ID:	28897Click image for larger version  Name:	_DSC4469.jpg Views:	1 Size:	82.9 KB ID:	28904
    The rudders use Spektrum A6150 HV servos, elevators use Spektrum A6260 Hi Torque HV servos
    The engine is a DA170 with KS Comfort Mount Headers, MTW tuned pipes, and a custom aluminum motor mount. Spinner is a Tru-Turn, and the prop is an Air Models 29 x 12 carbon fiber.
    Click image for larger version  Name:	_DSC4640.jpg Views:	1 Size:	93.9 KB ID:	28913Click image for larger version  Name:	_DSC4655.jpg Views:	1 Size:	86.1 KB ID:	28914 Click image for larger version  Name:	_DSC4643.jpg Views:	1 Size:	106.6 KB ID:	28915
    Click image for larger version  Name:	image_10963.jpg Views:	1 Size:	173.2 KB ID:	28907 Click image for larger version  Name:	image_10964.jpg Views:	1 Size:	116.4 KB ID:	28908
    Click image for larger version  Name:	image_10972.jpg Views:	1 Size:	58.0 KB ID:	28916Click image for larger version  Name:	image_10973.jpg Views:	1 Size:	57.1 KB ID:	28917
    Click image for larger version  Name:	_DSC4601.jpg Views:	1 Size:	265.6 KB ID:	28911Click image for larger version  Name:	_DSC4605.jpg Views:	1 Size:	252.6 KB ID:	28910
    Click image for larger version  Name:	_DSC4613.jpg Views:	1 Size:	209.7 KB ID:	28909Click image for larger version  Name:	_DSC4609.jpg Views:	1 Size:	213.5 KB ID:	28912
    MTW RE3 Pipes and detail of damage to them: I don't know if these can be repaired at all or if they are usable, but they will be provided with the engine of purchased as a whole package
    Click image for larger version  Name:	_DSC4514.jpg Views:	1 Size:	158.6 KB ID:	28918Click image for larger version  Name:	_DSC4525.jpg Views:	1 Size:	150.2 KB ID:	28921
    Click image for larger version  Name:	_DSC4521.jpg Views:	1 Size:	160.6 KB ID:	28919Click image for larger version  Name:	_DSC4529.jpg Views:	1 Size:	159.3 KB ID:	28920
    Here are pictures of the damegd area of the fuselage:
    Click image for larger version  Name:	_DSC4575.jpg Views:	1 Size:	151.0 KB ID:	28867Click image for larger version  Name:	_DSC4578.jpg Views:	1 Size:	187.8 KB ID:	28868
    Click image for larger version  Name:	_DSC4590.jpg Views:	1 Size:	230.6 KB ID:	28869Click image for larger version  Name:	_DSC4583.jpg Views:	1 Size:	206.6 KB ID:	28870
    Click image for larger version  Name:	_DSC4558.jpg Views:	1 Size:	80.1 KB ID:	28871Click image for larger version  Name:	_DSC4553.jpg Views:	1 Size:	83.6 KB ID:	28875Click image for larger version  Name:	_DSC4551.jpg Views:	1 Size:	79.9 KB ID:	28873
    Click image for larger version  Name:	_DSC4533.jpg Views:	1 Size:	157.6 KB ID:	28874Click image for larger version  Name:	_DSC4537.jpg Views:	1 Size:	194.0 KB ID:	28872
    This would require some rebuilding of the fuselage bottom, addition of triangular stock, and reinforcement as needed for the main landing gear block.
    The main gear and wheels are not damaged at all. The main gear plate was reinforced with an additional aluminum plate, seen in the photo above.
    Send a PM if interested.
    Thanks !
    Bob
      SOLD !
      Thank you everyone for looking.
      Bob
