Len's Czmelak "Smellyak" build
  • #61
    Len, Do you think my belts and suspenders design I used on the wing latches on my Bidule would have solved the problem? Has to be some sort of air frame resonance that is vibrating the latch loose. Makes my wonder about using 4 latches on the next Bidule build vs just 2 and 2 bolts.....
    • #62
      It appears to be a pulling force. The locks are fine, and they are set up correctly but the wing pulls pulls out and spreads the fork. I think two may have been ok, or one further forward and one further back.
      • #63
        also, the receiver cam has a radius on the inside which allows the fork to wedge off if there is a pulling motion, if that was a sharp 90 it would probably solve the. issue too.
        • #64
          This was our favourite tug in the PNW until it hit a runway light at the Arlington airport
          Steve Dentz' beauty with a Moki 250......mmmmmm
          • #65
            Thats. AWESOME !!!!
            • #66
              I use 4 latches on the Turbine Porter with no issues and 2 on the B4 with no problems, common denominator is neither have vibration! Just my 2 planes worth
              • #67
                I have them on the Bidule without. issues?
                • #68
                  Baldrick on the Cmelek
