Epoxy options
  • Epoxy options
    Well my electric tow plane threw a motor magnet yesterday. Easy fix if I knew what glue to use. I am pretty sure the standard epoxy will not hold up with the heat. Anyone have a suggestion for epoxy that is good under high heat.
    JB Weld
    Order J-B Weld Gray Epoxy Putty, 2 oz. Tube, 8297 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.
      Ya, several folks said the same. I had some 6 min stuff which I used today. After 4 hour recommended cure time I ran the motor up with and without a prop. Only went to about 75%, but all went well except for the two motor mount screws I did not fully tighten.
      All is well at the end. Towing test next week.
      Thanks
