Moore Crystal Clear discontinued???
  • Moore Crystal Clear discontinued???
    My local drafting supply store told me Moore no longer makes the stuff and it's scarce online, with many places charging crazy high prices. I'm going to try this stuff called Holotap Ultra Transparent. It has the same "would not turn yellow over time" selling point. Hopefully it's as nice as the Moore's was, otherwise I'm going to have to buy a lifetime supply before it all disappears.
    What is it?
    TEAM GORGEOUS
      Yeah, what is it?
        Ok, its a tape.
          I’m a fan of this product for tape hinges. Durable, exceptionally thin. From the UK...
          Click image for larger versionName:	Views:	1Size:	124.3 KBID:	34374
            I'm sorry. I thought it was more commonly known in the sailplane circles as a great tape for covering servo bays and other useful applications. It's stays flexible and clear over a very long period of time.
              I’m a fan of this for tape hinges. From the UK...
              Looks like that tape may have been disontinued too. I really love Blenderm by 3M but it's not really clear and doesn't look as good on servo hatches. It's really strong and flexible for taping wing joints though.
                Well.....this is a forum dedicated to scale sailplanes......most of which don’t use clear tape to cover servo’s......now for field repairs of a fabric covered airframe it might be useful.
                TEAM GORGEOUS
                  Clear tape on fabric... not on your life! lol
                So what do you use to attach the servo bay covers? I've never seen anyone glue them on. And gap seal tape? Blenderm works great for the latter but it isn't quite clear if you are looking for tape that almost disappears after applied. I guess you could use white, but most tape manufacturers don't care what color white your plane is?
                  This site is dedicated to helping our fellow flyers.
                  Many of us are sailplane hobbists first, scale second. BTW, you can still find the clear at some of the UK suppliers but it takes a hunt. Scotch book binding tape in clear is another good option.
                  For servo covers on scale ships, sign vinyl in the color of the wing bottom or stripe pattern is a a good option because a piece can be cut exactly to the size and contour of the servo cover plus some overlap making a seamless single piece application. Callie will sell one or two square foot pieces of raw vinyl and send with with her graphic orders — a great way to stock up on a range of colors. Or, good old white. U.S. Cutter is another good source for small pieces such as Oracal 651 or Evergreen by the running foot.. Sign vinyl always comes in handy to make stripes and such on wing bottoms as well for added visibility.
                  Good luck with your search.
                    This site is for dedicated to helping our fellow flyers. Many of us are sailplane hobbists first, scale second. BTW, you can still find the clear at some of the UK suppliers but it takes a hunt. Scotch book binding tape in clear is another good option.
                    Cool. I've got a couple of local sources for all things related to sign vinyl/car wrap vinyl, custom stickers etc. Thanks
                      Servo covers are attached will a small amount on silicone or goop........never use gap seal tape since these are scale sailplanes and not TD compition airframes and extracting every once of performance out of them isn’t really something I’m concerned with.....and as far as taping panels together good old 3M white electrical tape works just fine.....sold at HomeDepot/Lowe’s.....
                      TEAM GORGEOUS
                        Uline Crystal Clear tape works well for servo covers, hinge tape, canopy repair, etc. Super thin and flexible. Comes in 1/2", 3/4", and 1" widths. I buy it by the case so if you have a problem getting it let me know.
                        Regards Dean
                          Regards Dean
                          Thanks Dean.
                            If it means getting back in the air to fly some more then yes by all means! To repair damaged fabric you need to cut it back to the nearest wood edge.......which means cutting out any “tape” repair........I would rather fly with a tape patch then not fly since the patch will be cut out anyway once you’re back in the shop and do a “proper” repair!
                            TEAM GORGEOUS
                              I understand. That's why I put the 'lol' on there! Honestly though if my Eaglet or some other got a hole in it then it goes back in its box until a proper repair is effected. I can patch hole from the inside with my 'special tools' and that doesn't require cutting more fabric in many cases! I can fly sump'n else in the meantime!
