1/4 Scale ​1954 Scheibe Bergfalke Mü13 E build
  • 1/4 Scale ​1954 Scheibe Bergfalke Mü13 E build
    Here's my build on Chris Williams 1/4 Scale 1954 Scheibe Bergfalke Mü 13 E plans. Wonderful vintage retro sailplane.
    Jump into the hot tub time machine and lets set the date for sometime in 2012. I helped contribute to the CAD drafting and converting the hand drawn plans for laser cutting. Gearing up from my normal RC routine of custom EPO 2m sailplanes, uber detailed scale Porsche slot cars and RC Porsche cars, I was in need of a big work bench. So, built two all new work benches for 1/4 scale sailplane builds (since the below build photos were shot, I've upgraded the lighting). I started my build on October, 2013, hopefully I can get this done this winter, spring of 2016.
    Lining up the formers
    My cat making sure I do it correctly...
    Klassische Segelflugzeuge
    More fuselage building
    Adding in 1/4" x 1/4" balsa cross-supports
    The original plans use Graupner 14mm wing joiner blade. The laser kit is converted to a solid bar with brass retainer tube.
      Front area fuselage tubular frame details on how I added the 1/4 dowel.
      Off the jig, ready to start on the nose.
      Labyrinth of 1/4" balsa supports and UHU Hart!
      Adding in 1/4" balsa to keel area
      Notching tube frame dowels for additional sitka spruce longeron.
        Adding Multiplex Cularis aerotow nose piece.
          Sketch for the 1/32" ply template on velum.
          Glue used is Gorilla WOOD glue for 1/32" ply to fuselage formers and Sitka Spruce.
            Working on the nose details.
            Landing gear wheel shaft
            Kavan wheel
            Insert stainless steel axle shaft, tap for allen nut
              Adding lower keel, landing gear shape/support area
              Filling in front skid area
              Tracing skid shape with vellum
                After reviewing many photos of the real Bergfalke, I wanted to adjust the shape of the nose profile ever so slightly.
                Making sure this old girl looks the part!
                  Removing the formers to create a scale interior.
                  Tracing the floor, hey a piece of Sitka Spruce bends great!
                  Made it two pieces for better access.
                    Wow! This is really nice! I haven't built a model in an 'up-in-the-air' jig before. It sure keeps everything straight. With all those sticks and beveled cuts I 'understand'! lol
                      Very Impressive Thompson.
                      Thanks for the re-post...
                        Thanks guys, yes its getting there. I still have some more photos to post, then I'll be caught back up to where it is now.
                          Looks great Thompson! It makes me want to break out my 1/3 scale Bayer CNC Minimoa kit and scratch my head over the German instructions....like I have been doing for 15 years LOL
                            I'm determined to get this finished THIS year, hopefully maiden at SeptemberSoar. I have three other kits to finish also (1/4 scale L-Spatz 55 [redesign of orig German plan] and some hydroplanes). I need to put my brain into a Chris Williams level build mode and crank these out. I'll be posting more photos today.
                            Cheers, Thompson
                              Thompson,
                              Nice to see you back at the build. Looking forward to the maiden flight.
