Wrocitem! The rear spar is angled where the ailerons start so a nice accurate cut was made then epoxy used for the joint. The angled portion was jigged to induce washout. The front spar was partially assembled so that everything is square as it holds the socket. Shear webs get added after the ribs are threaded in place.
wiecej...
wiecej...
