Your craftmanship is second to none, a joy to study, just wondering have you created an unmix program for the stick so that a rudder input doesnt move the stick if you are Y leading from the normal servo out puts to the function?
Thanks Gunny 11,
Worked on the hinge supports for the stabilizer side of the tail. The plans show no support for the hinge aft of the spar. This was just not acceptable in my mind so changes were made. Vertical grain blocks were glued to the stabilizer spar supporting the hinge to near the pivot location. Spacers (64th ply) were placed on each side to center the 3/16 wide blocks between the radius plates of the elevator. When final assembly is made the hinge will be epoxy flush on both sides to the support blocks. At least that is the concept so far.5 Photos
Using the Ammonia method, for the first time, to soften the balsa wood worked out great. To keep it uniform the 1/16th balsa sheet was taped over a 1.25" dia rod to dry. It was then just a matter of cutting it to length, trimming and gluing in place. When the glue cured the hinge slots were trimmed flush to the radius plates. The elevator hinge pin also incorporates the drive link pin as a single unit. This way there is only one pin to misplace and being such an odd shape is unlikely.
The leading radius of the elevators need to be sanded to profile before the 2mm balsa sheeting is applied using the Ammonia method once more. The drive link pivot plates can then be fitted and epoxy in place. At least that's the plan.6 PhotosLast edited by Gene C; 07-19-2018, 03:19 AM.
Some help required!
With the elevators slotted for travel, what is enough? I know that the total travel is max elevator + max rudder. The elevator chord from the pivot pin is 7.5 " so just how much travel is required on such a large control surface. At present with the current slotting there is 2.25" up and 1.875" down at the trailing edge. Not a hint in the manual, even in German and the plans show zip.
Thanks for any help,
Gene1 Photo
Finished hinging the elevators and mounting the control plates the other day. The stabilizer hinge supports were filled with West Systems 105 epoxy and 401 filler then clamped with wax paper and plywood backing on each side. After the epoxy set up firm but not hard the backing was removed and the excess epoxy removed while the wax paper was still in place. After fully cured the wax paper was easily removed from the hinge supports.
Looking forward to mounting the servos and giving it a try, but that well have to wait at least a week until the servos to arrive.5 Photos
It's now time to turn my attention back to the fuselage while waiting on servos. The tow release, radio and release servo platforms were installed. The release servo is removable buy use of a plate mount system. The operational force is against a solid stop so only a #2 servo screw is required to keep it in place. All the fuselage doweling will get a thin coat of epoxy before the light Gray finish paint is applied.5 Photos
I got up the courage the other day to route the skid groves for securing the fabric covering.
After a coat of epoxy was applied to all the fuselage doweling, a weight check was in order. Maybe casting the pilot figure in lead could add ballast.5 Photos
It's a blocked start but the Ka-3 must have a pilot. The only one in 40% that might have worked, beside an Axel, did not have a removable head set. The vintage look of the pilot will not be anyone in particular but hopefully have European features, what ever they are. The starting base was cut out of 2 lb 4" thick blue foam.
There are several links to carving faces on line so why not at least give it a try.
3 Photos
