After doing the two upper and two lower sections of wing sheeting we are more confident about how to size them. Basically, we cut them just 5mm oversize this time. The 48" x 1-1/2" aluminum angle makes a good straight edge to cut against.
Apply glue to both surfaces and spread out into a nice thin layer. Wait until the white turns clear and then use the hot iron and water spritzer to apply to the framework. Very slick!
The balsa leading edge worked perfectly. Allowed plenty of down pressure with the hot iron to apply the sheeting.
