Aviation Concepts 1/3-scale Schweizer 2-33 ~ Build Thread by JimD
    These 1/3 scale kits are back in stock! Building season is upon us now!
    www.aviationconceptsrc.com
      Please keep designing great Schweizers ...
        Ps, I love the scale grass clippings on the nose..
      Thanks David, welcome to the forum! Nice shot of your #5.
      I really enjoy flying mine a lot....
      p.s. David's 1/3 scale was the first one to take flight in Canada. 😀
        Before completing the bottom section of the fuselage (and while it will still flat on the bench), we are moving on to the wings. Once the wings are completed to the point that they can be set on top of the fuselage, the holes for the wing bolts can be drilled. This process is a lot easier with the fuselage sitting flat on the work surface.
        Plans were attached to the work surface and covered with wax paper. Next, we located the parts necessary to start the wing build.
          Got all of the ribs and other wing parts separated from the carrier sheets and organized. Shimmed the spars over the plan as Gunny suggests and we were off to the races! Excellent laser cutting and perfect parts fit on this kit, having a great time watching the wings come together.
            Wing strut mounts need to be angled correctly.
            Click image for larger version  Name:	IMG_6637.JPG Views:	1 Size:	80.8 KB ID:	32874
            Click image for larger version  Name:	IMG_6638.JPG Views:	1 Size:	88.5 KB ID:	32875
            Click image for larger version  Name:	IMG_6640.JPG Views:	1 Size:	78.3 KB ID:	32876
            Click image for larger version  Name:	IMG_6641.JPG Views:	1 Size:	78.5 KB ID:	32878
            Top Spar clamped in place at root.
            Click image for larger version  Name:	IMG_6639.JPG Views:	1 Size:	99.7 KB ID:	32877
            Time to mix epoxy!
            Click image for larger version  Name:	IMG_6646.JPG Views:	1 Size:	89.7 KB ID:	32881
            Click image for larger version  Name:	IMG_6647.JPG Views:	1 Size:	81.1 KB ID:	32879
            Click image for larger version  Name:	IMG_6648.JPG Views:	1 Size:	102.1 KB ID:	32873
            Then add the last two ribs to the main wing panels and then the top drag spar.
            Click image for larger version  Name:	IMG_6651.JPG Views:	1 Size:	105.2 KB ID:	32882
            Click image for larger version  Name:	IMG_6652.JPG Views:	1 Size:	112.0 KB ID:	32880
              1/8" Balsa shear webs are added to both sides of the main spar and at the inboard 2 bays and last outboard bay of the drag spar.
                Last step in this phase of the inner wing panel build is to install the wing joiner dowel and add triangle under the wing bolt plates.
                At this point, Gunny instructs the builder to assemble his wing jig (included in the kit). This jig can be configured for building either a right or left wing. Thanks to Tom M, I have a second set of jig parts. He kindly gave me his set after completing his model.
                  Go Jim, Go! Your going to love the jiggy Mc-Thingy...
