Vintage Hungarian Glider
  • Vintage Hungarian Glider
    Hi there.
    Crossed whit this beautifull old glider in the internet. Unfortunaly this model is unviable to me here, in Brazil. I'm looking for pdf plans to laser cut in a local shop. Have does anybody have this plans?
    Updating: just found a huge amount of drawings and text about R07b and other gliders and planes designed by hungarians -
      Well, not easy to navigate in Hungarian..
      do you have a link to the sailplane section?
      Team Horizon
        It looks similar to a 'Hols de Teufel' or a 'Salamandra'. Those three views are available on line(?) and in Martin Simons' books. It would be a fairly simple model to build without the need for laser cutting. Only one or two rib templates needed and the fuselage cross sections should not be too hard to hand draw. Good luck with the build!
          You're right, Arup. Seems a pretty simple building… I'm going for it and hope to have time to share here. Also I found a lot of good looking japanese soaring planes - https://translate.google.com.br/tran...tml&edit-text= (translated from japanese to portuguese).
