1954 Scheibe Flugzeugbau L-Spatz 55
  • 1954 Scheibe Flugzeugbau L-Spatz 55
    Information
    The Scheibe Spatz (German: "Sparrow") is a German glider with a mixed metal and wood construction that was built in 1952 until 1962. Later versions were known as the L-Spatz, the letter L standing for Leistung, which is German for "performance".
    Scheibe Flugzeugbau built the Spatz A in 1952. Two years later in 1954 the first L-Spatz 55 was airborne. Three hundred L-Spatz 55s were built in Germany, 155 were produced in France under the name A.60 Fauconnet, and 16 produced under in Italy named MS-30 L Passero. This model was discontinued in 1962.
    It is a single-seater cantilever shoulder-winged sailplane with a cruising (max L/D) speed of 45 mph. It has an empty weight of 157 kg and a maximum take-off weight of 269 kg. The single spar wing and tail were constructed using fabric-covered wood, whereas the fuselage consisted of steel tubing covered with fabric.
    The L-Spatz 55 has good climbing performance due to light construction. The glide angle is 29:1. The longest known cross-country flight was more than 600 km from Burg Feuerstein, Germany to France.
    Many gliding clubs operated the L-Spatz 55, well known for its easy handling. Recovery from a spin in the L-Spatz 55 is easy.
    Variants
    Spatz A
    Certified in 1952 with a 13.20 metre wingspan, 6.19 m length.
    Spatz B
    Strengthened and improved variant with a 13.20 metre wingspan, 6.19 m length, certified in 1952.
    Spatz 55
    Certified in 1952 with a 13.20 metre wingspan, 6.25 m length.
    L-Spatz
    Certified in 1954 with a 15.00 metre wingspan, 6.05 m length.
    L-Spatz 55
    Certified in 1954 with a 15.00 metre wingspan, 6.25 m length.
    L-Spatz III
    Certified in 1966 with a 15.00 metre wingspan, 6.25 m length.
    Specifications (L-Spatz 55)
    Data from The World's Sailplanes ie Segelflugzeuge der Welt:Les Planeurs du Monde
    General characteristics
    Crew: 1
    Length: 6.25 m (20 ft 6 in)
    Wingspan: 15 m (49 ft 3 in)
    Wing area: 11.7 m2 (126 sq ft)
    Aspect ratio: 19
    Airfoil: Mü-Profil 14%
    Empty weight: 153 kg (337 lb)
    Max takeoff weight: 265 kg (584 lb)
    Performance
    Never exceed speed: 180 km/h (112 mph; 97 kn)
    Rough air speed max: 110 km/h (68.4 mph; 59.4 kn)
    Aerotow speed: 110 km/h (68.4 mph; 59.4 kn)
    Winch launch max speed: 90 km/h (55.9 mph; 48.6 kn)
    Terminal velocity: 200 km/h (124.3 mph; 108.0 kn)
    g limits: +4 -2
    Maximum glide ratio: 29 at 80 km/h (49.7 mph; 43.2 kn)
    Rate of sink: 0.58 m/s (114 ft/min) at 67 km/h (41.6 mph; 36.2 kn)
    Wing loading: 22.6 kg/m2 (4.6 lb/sq ft)
    Link https://en.wikipedia.org/wiki/Scheibe_Spatz
    Available Kits, RC Plans
    Scale 1: 3.83
    Wingspan: 3.92 m
    Weight: 3700 g
    Profile: E 207-E 205
    Printed plans http://shop.vth.de/l-spatz-55.html
    Build photos, documentation from scale 1: 3.83 plans (very detailed photography, in German)
    http://www.rc-network.de/forum/showt...513-L-Spatz-55
    http://www.oliver-theede-oldtimerseg...lerieklein.htm
    Scale 1: 2,5
    Wingspan: 6,0 m
    Weight: 11,500 g
    Printed plans Contact Oliver Theede http://www.oliver-theede-oldtimerseg...Gaestebuch.htm
    Build photos, documentation from scale 1:2,5
    http://www.oliver-theede-oldtimerseg...baubilder2.htm
    Scale Documentation, Original Plans
    Link http://www.oliver-theede-oldtimersegler.de/l-spatz1.htm
    Link http://www.oliver-theede-oldtimersegler.de/l-spatz2.htm
    Photography, Details
    Airframe, "Rumpf"
    Scheibe L-Spatz 55, SE-TCF, Aeroseum, Sweden
    Photo: Al Stacey http://www.abpic.co.uk/photo/1177594/
    Photo: George Trussell http://www.abpic.co.uk/photo/1212632/
    Different liveries, color options
    Scheibe L-Spatz 55, D-8376, Private. Gutersloh (GUT / ETUO) , Germany
    Construction Nr. 2720
    Scan from a slide, June 1984. Became RAFGGA 537, later BGA3412 / FPF.
    Photo: Al Stacey http://www.abpic.co.uk/photo/1389622/
    Scheibe L-Spatz 55, OE-0479, Private, Wiener Neustadt-West (LOXN), Austria
    Construction Nr. R55/H227
    Photo: George Trussell http://www.abpic.co.uk/photo/1321731/
    Scheibe L-Spatz 55, D-9187, Sinscheim, Auto und Technik Museum, Germany
    Construction Nr. 565
    Photo: Al Stacey http://www.abpic.co.uk/photo/1125595/
      Scheibe L-Spatz 55, D-1980, Sinscheim, Auto & Technik Museum, Germany
      Photo: Al Stacey http://www.abpic.co.uk/photo/1125510/
      Scheibe L-Spatz 55, D-3632, Private, Speyer (ZQC / EDRY), Germany
      Photo: Al Stacey http://www.abpic.co.uk/photo/1125336/
      Scheibe L-Spatz 55, RAFGGA 537, Private, Gutersloh (GUT / ETUO), Germany
      Photo: Al Stacey http://www.abpic.co.uk/photo/1064178/
        Thompson, nice job documenting this aircraft.
